Question on applying exponentially stretched grid in the vertical direction. |
December 19, 2023, 05:24 |
DENGGEFEI
Rep Power: 3 |
hello,
I want to transform a code( Rans-2DV-WENO-SIMPLIC- sigma Coordinate) into a vertical streched version to statifity the y+ condition in deep waters. The original code use a uniform mesh in the vertical, the vertical grid number is 8000 to meet y+=100 in my simulation, which is too expensive. Therefore, I should apply the vertical stretched version. But I have no idea how to use the exponentially stretched grid. Could some one be so nice to tell me how to deal with it? Is there any example to study? I think there should be a transform function, so the compution domain is uniform, and the scheme used in the original code still works. thanks in advance |
December 19, 2023, 08:42 |
Filippo Maria Denaro
Rep Power: 73 |
Why do you want to compute the discrete derivatives in the computational plane? Use the formula for non uniform grid.
December 19, 2023, 09:50 |
DENGGEFEI
Rep Power: 3 |
Hello FMDenaro, the original code apply a geometric multigrid with red-black SOR method to solve possion function, and the advection is sloved by the WENO scheme. In the computational plane(uniform grid)these scheme may work. This is why i want to do calculations in the computational plane. Very thanks to you.
December 19, 2023, 10:47 |
#4 | |
Rep Power: 73 |
https://www.researchgate.net/publica...-uniform_grids But you need to transform the equations from the physical to the computational plane. This is a topic you can find in the classic textbooks about structured grid generations. |
December 19, 2023, 11:03 |
DENGGEFEI
Rep Power: 3 |
Thanks very much, FMDenaro.
I hope tp do the exponentially stretched grid in the sigma coordinate. In the physical domain, the bottom is the sea bed and the up is the free-surface. In the computational domain 1 (for the original code), the bottom is 0 and the up is 1. This transformation is clear and many model does this. However, when I want to use stretched grid in the computational domain 1, and by some transformation like sigma-transformation, the stretched grid will be uniform in the computational domain 2 (for the stretched code version), and the scheme used in the original code can be easily applied into the stretched one. |
December 19, 2023, 11:09 |
#6 | |
Rep Power: 73 |
yes, but there is the fact you need the metric, that is the Jacobian for the derivatives. |
December 19, 2023, 22:59 |
DENGGEFEI
Rep Power: 3 |
Thanks very much.I will learn from your suggestion
rans, stretched grid |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 04:33 |
Solution breaks on highly stretched grid | crazyshock | Main CFD Forum | 0 | October 16, 2017 17:26 |
Moving Body Grid Question | Matt | Main CFD Forum | 5 | September 13, 2004 01:45 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
grid spacing question | clifford bradford | Main CFD Forum | 5 | November 10, 1999 19:40 |
