Seeking Insights on Modeling Low-Concentration Sand Slurry Flow in Horizontal Pipes |
rshettCFD
Rep Power: 2 ![]() |
Hello Community,
I'm currently engaged in a project involving the simulation of low-concentration sand slurry flow through horizontal pipes. This process is characterized by transient sand injection, which occurs after the water phase has achieved a fully developed state. My approach utilizes the k-w SST turbulence model. The system I'm working with features a pipe that is 12 meters long and has a diameter of 0.0508 meters. Both experimental and analytical models suggest that the sand should remain in a heterogeneous suspension. However, in my simulations, I'm observing a quicker settlement of sand compared to its transport by the carrier phase, which is contrary to expectations. Efforts to rectify this include tweaking various parameters such as the specularity coefficient and experimenting with the k-epsilon turbulence model, but these modifications haven't been successful in maintaining the sand in suspension. I have two primary queries where I would greatly appreciate your expertise and suggestions: How crucial is mesh refinement in this context, and what strategies can I employ to balance the need for a fine mesh with computational efficiency? Would enhancing the mesh resolution significantly impact the accuracy of simulating settling slurries? When defining the material properties for sand in the simulation, what viscosity values should be considered? Your insights and recommendations on these matters would be invaluable to my research. Thank you for your time and assistance. Best regards, Rishi |
rshettCFD
I believe I've found the solution to the issue I was experiencing. The root cause appears to be the surface roughness setting, which was initially set to zero. By adjusting the roughness height to the diameter of a particle and setting the roughness constant to 0.75, I observed that the pressure gradient increases, likely due to enhanced friction. This change results in a greater drag force on the particles.
I welcome any additional advice for fine-tuning the model. Also, I'm currently using the default value for the granular temperature of the sand phase, which is 0.0001 mē/sē. I'm wondering if this should be adjusted. Any suggestions on this would be appreciated. Best regards |
apparant viscosity, mesh refinement, sand slurry flow in pipes, turbulence modeling |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
