December 18, 2023, 06:34 |
rotation of fluid particle
Rep Power: 4 |
Hello guys
I've watched video of below link. https://www.youtube.com/watch?v=p_82...X2o4TX&index=3 Since 33:48, angular momentum conservation of flow particle is derived. This derivation is showing symmetric of shear stress. () At here, all of angular acceleration related terms(Kinetic terms) are removed. Then does it means rotation is always steady state no matter which kind of flow is imposed? But as far as I know rotation is defined as below . By upper formula, rotation depends on velocity field so that if there is unsteady flow field, rotation is different depending on time. I'm confused between this and angular momentum conservation of flow particle. What is right? Thank you |
rotation, theory |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
DPM : Fluid velocity at particle position ? | souria | Fluent Multiphase | 1 | January 30, 2015 05:58 |
Particle Transport in Fluid Stream. How to keep them in the fluid! | kavanaa1 | FLOW-3D | 2 | September 19, 2012 00:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Particle tracking in s.s and u.s.s fluid field. | yueroo | FLUENT | 0 | April 6, 2001 22:02 |
