Multiphase - Boundary Condition for 2 Outlets having 5000Pa differential |
Rep Power: 2 ![]() |
I have a case where the inlet velocity and pressure is specified to a fixed value. There are 2 outlets where the second outlet is to be set 5000Pa above the first outlet, but the solver needs to calculate the outlet pressure for both outlets (outlet_b = outlet_a+5000Pa). this is multiphase, using interFoam what is the recommended way to do this? thanks |
boundary condition, differential pressure |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Opening boundary condition for multiphase analysis in CFX | shivasluzz | CFX | 3 | May 15, 2015 09:49 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
