SOFC 999999: mpt_accept: error : accept failed: No such file or Directory
Old   December 12, 2023, 09:25
Default SOFC 999999: mpt_accept: error : accept failed: No such file or Directory
Cagatay Necati Dagli
cagataynecatidagli is on a distinguished road
Hello everyone,
I would like to simulate a SOFC with the help of Ansys Fluent 2023 (SOFC with unresolved electrolyte). My model and description of all components are attached. I have a wall to wall-shadow relationship between anode and cathode, which means that I do not resolve my electrolyte. The electrolyte is only defined by a thickness in the SOFC calculation console.
I set all the boundary conditions and initialize the problem. Up to this point, no errors occur. As soon as I want to start a calculation, I get the following error code:
After receiving this error, Fluent crashes immediately. In several online forums I could already find the information that Fluent should be started in series instead of parallel. This is not possible in Ansys Fluent 2023 (unlike in 2019!). Depending on how many cores I use, I get the same .txt error code file x times. I have a suspicion that there is incorrect access to the cores, to which I could not find an answer.
cagataynecatidagli is offline   Reply With Quote
mpt_accept error, parallel calculation, serial in parallel, serial parallel multicore, sofc udf ansys cfd fluent
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
