Regarding multiphase simulation convergence
Old   December 10, 2023, 06:38
Default Regarding multiphase simulation convergence
SphericalCube is on a distinguished road
Hi all,
So, I am trying to do a multiphase simulation, more specifically, a bubble column that includes the PBE. The problem is solved transiently, however, I am only interested in the 'steady-state' solution.
I am able to get the thing to converge. But compared with experimental data and CFD studies that solved the same setup the results are not quite right.
I have been looking for tips and tricks/strategies to get the multiphase simulations to converge correctly. But I haven't found much, except a little in the Fluent users guide.
What I'm doing right now is to first compute an initial solution with 1st order schemes and without the PBE, then I continue the solution with higher order schemes for some time, and last, add the PBE.
I was wondering if this is an okay approach? Does adding in the higher order schemes actually "refine" the solution. Or should I maybe try to start the simulation with higher order schemes instead? Is it okay to add the PBE in later?
Also, any general tips or literature on how to get multiphase solutions to converge to the correct solution would be much appreciated!
SphericalCube is offline   Reply With Quote
bubble columns, multiphase
Multiphase simulation taking too long allenpv Fluent Multiphase 1 March 3, 2021 07:09
Fatal overflow in linear solver and simulation never show convergence Wong0912 CFX 1 March 2, 2021 17:59
Multiphase Simulation - Fluent vinayak4399 Fluent Multiphase 3 December 13, 2015 12:46
How to get better convergence in transient simulation sjtusyc CFX 36 April 29, 2013 00:19
multiphase simulation... 2D flow through an elbow Tim CFX 10 April 3, 2008 19:13
