Inquiry Regarding Obtaining Chemical Time Scales in OpenFOAM
Old   December 7, 2023, 05:23
Default Inquiry Regarding Obtaining Chemical Time Scales in OpenFOAM
Niyas
niyas is on a distinguished road
Dear CFD Community,
I am currently working on a combustion simulation using OpenFOAM v06 and aiming to extract and analyze the distribution of chemical time scales within the simulated domain. I have employed the Eddy Dissipation Concept (EDC) combustion model for this purpose.
I would appreciate any expertise in guiding me through the process of obtaining and visualizing the chemical time scale data in OpenFOAM. Specifically, I am interested in understanding the steps involved in post-processing.
Any insights, examples, or references you could provide would be immensely helpful.
Thank you in advance for your assistance.
Regards,
Niyas
niyas is offline   Reply With Quote
Old   December 7, 2023, 19:52
Niyas
Any guidance on this topic would be appreciated !!!!
Regards,
Niyas
Old   September 29, 2024, 18:14
Smile Extracting Chemical and Mixing Time Scale in PaSR Model
Harsh Anand
GeekCFD is on a distinguished road
Hi niyas,
I know my reply is a bit late, but it would be helpful for others.
I have successfully extracted the Chemical and Mixing Time Scales from the PaSR Model in OpenFOAM (renamed it as openFOAMPaSR).
I think a similar process can be employed for the EDC Model too.
I have provided the source code below for reference.
The input-output files for tauC and tauM have been created and the values are being written into it for each cell in the domain.
openFOAMPaSR.C File:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2017 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "openFOAMPaSR.H"
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
template<class ReactionThermo>
Foam::combustionModels::openFOAMPaSR<ReactionThermo>::openFOAMPaSR
    const word& modelType,
    ReactionThermo& thermo,
    const compressibleTurbulenceModel& turb,
    const word& combustionProperties
    laminar<ReactionThermo>(modelType, thermo, turb, combustionProperties),
    Cmix_(this->coeffs().getScalar("Cmix")),
    kappa_
        IOobject
            thermo.phasePropertyName(typeName + ":kappa"),
            this->mesh().time().timeName(),
            this->mesh(),
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        this->mesh(),
        dimensionedScalar(dimless, Zero)
    tauM_
        IOobject
            "mixingTimeScale",
            this->mesh(),
            IOobject::NO_READ,
        this->mesh(),
        dimensionedScalar("mixingTimeScale", dimTime, 0)
    tauC_
        IOobject
            "chemTimeScale",
            this->mesh(),
            IOobject::NO_READ,
        this->mesh(),
        dimensionedScalar("chemTimeScale", dimTime, 0)
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::combustionModels::openFOAMPaSR<ReactionThermo>::~openFOAMPaSR()
// * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
void Foam::combustionModels::openFOAMPaSR<ReactionThermo>::correct()
    if (this->active())
        laminar<ReactionThermo>::correct();
	// Access turbulence quantities ---> epsilon and muEff
	tmp<volScalarField> tepsilon(this->turbulence().epsilon());
        const scalarField& epsilon = tepsilon();
        tmp<volScalarField> tmuEff(this->turbulence().muEff());
        const scalarField& muEff = tmuEff();
        // Access chemical time scale
        tmp<volScalarField> ttc(this->tc());
        const scalarField& tc = ttc();
        // Access density
        tmp<volScalarField> trho(this->rho());
        const scalarField& rho = trho();
        forAll(epsilon, i)
            const scalar tauM_i = Cmix_ * sqrt(max(muEff[i] / rho[i] / (epsilon[i] + SMALL), 0));
            if (tauM_i > SMALL)
                kappa_[i] = tc[i]/(tc[i] + tauM_i);
            else
                kappa_[i] = 1.0;
	    // Store the computed 'tauC' and 'tauM' value for visualization
	    tauC_[i] = tc[i];
	    tauM_[i] = tauM_i;
Foam::tmp<Foam::fvScalarMatrix>
Foam::combustionModels::openFOAMPaSR<ReactionThermo>::R(volScalarField& Y) const
    return kappa_*laminar<ReactionThermo>::R(Y);
Foam::tmp<Foam::volScalarField>
Foam::combustionModels::openFOAMPaSR<ReactionThermo>::Qdot() const
    return tmp<volScalarField>
        new volScalarField
            this->thermo().phasePropertyName(typeName + ":Qdot"),
            kappa_*laminar<ReactionThermo>::Qdot()
bool Foam::combustionModels::openFOAMPaSR<ReactionThermo>::read()
    if (laminar<ReactionThermo>::read())
        this->coeffs().readEntry("Cmix", Cmix_);
        return true;
    else
        return false;
openFOAMPaSR.H File:
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
Class
Group
    grpCombustionModels
Description
    Partially stirred reactor turbulent combustion model.
    This model calculates a finite rate, based on both turbulence and chemistry
    time scales.  Depending on mesh resolution, the Cmix parameter can be used
    to scale the turbulence mixing time scale.
    Mixing time scale is calculated as Cmix * sqrt(nuEff / epsilon)
SourceFiles
    openFOAMPaSR.C
#ifndef openFOAMPaSR_H
#define openFOAMPaSR_H
#include "../laminar/laminar.H"
namespace Foam
namespace combustionModels
                            Class openFOAMPaSR Declaration
class openFOAMPaSR
    public laminar<ReactionThermo>
    // Private data
        //- Mixing constant
        scalar Cmix_;
        //- Mixing parameter
        volScalarField kappa_;
	// Field for mixing time scale
	volScalarField tauM_;
	// Field for chemical time scale
	volScalarField tauC_;
    // Private Member Functions
        //- No copy construct
        openFOAMPaSR(const openFOAMPaSR&) = delete;
        //- No copy assignment
        void operator=(const openFOAMPaSR&) = delete;
public:
    //- Runtime type information
    TypeName("openFOAMPaSR");
    // Constructors
        //- Construct from components
        openFOAMPaSR
    //- Destructor
    virtual ~openFOAMPaSR();
    // Member Functions
        //- Correct combustion rate
        virtual void correct();
        //- Fuel consumption rate matrix.
        virtual tmp<fvScalarMatrix> R(volScalarField& Y) const;
        //- Heat release rate [kg/m/s3]
        virtual tmp<volScalarField> Qdot() const;
        //- Update properties from given dictionary
        virtual bool read();
} // End namespace combustionModels
} // End namespace Foam
#ifdef NoRepository
    #include "openFOAMPaSR.C"
#endif
#endif
The openFOAMPaSRs.C file would remain the same as before.
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
#include "makeCombustionTypes.H"
#include "psiReactionThermo.H"
#include "rhoReactionThermo.H"
namespace Foam
makeCombustionTypes(openFOAMPaSR, psiReactionThermo);
makeCombustionTypes(openFOAMPaSR, rhoReactionThermo);
GeekCFD is offline   Reply With Quote
combustion, edc, openfoam, timescale
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
