Emre Demir
Rep Power: 0 ![]() |
Hi all,
I am trying to analyze NACA0015 in a steady state with the SST-K-omega turbulence model + SIMPLE method. My problem is analysis does not converge the solution even after 4000 iterations. I think the number should be less than 1.5k. AoA is 0 degree. Reynolds Number is 160.000 and velocity is about 16m/s. Chord length 190mm. Domain was created from the tail of the airfoil as shown in the attached image. As I checked from the previous subjects, the general suggestion is to check the mesh quality. You can also find its details in the attachment. Ortoghonal quality is above 0.88. Y+ is arranged as about 1. There are about 15 cells under the boundary layer. I tried to solve the problem with Couple method. However, for couple I am getting "Stabilizing pressure coupled to enhance linear solver robustness" warning. As I know it means that the program kindly asks me to change the solver method. I am waiting for your guidance and suggestions. What may be wrong? Thanks in advance. |
Tunahan Bayrakci
https://www.youtube.com/embed/HPsBuqWH9FY
Hello Emre I recommend you to watch this video |
#3 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Isn't too low the Re number to consider a fully developed turbulence? |
Emre Demir
I use "A Comparative Study on Turbulence Models for Simulation of Flow Past
NACA 0015 Airfoil Using OpenFOAM - Peerakit Kekina and Chakrit Suvanjumrat" as my reference for my study. Even if there is no fully developed turbulence, why can I not observe the transition? |
airfoil, converge, naca0015, simple |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
How to plot Tempersture vs Time in steady state analysis in Fluent Post? | Rajkool | Fluent Multiphase | 5 | August 4, 2021 05:21 |
Steady state conjugate heat transfer analysis in openfoam version 7 | srikarg | OpenFOAM Running, Solving & CFD | 3 | September 18, 2019 00:19 |
Steady state simpleFOAM crash | Galactus | OpenFOAM Running, Solving & CFD | 12 | August 14, 2019 06:06 |
Steady level flight airfoil analysis using ANSYS CFX v12 | flutter | CFX | 21 | March 29, 2016 03:51 |
