Y+ for rough surface
Old   November 30, 2023, 20:33
Question Y+ for rough surface
Rana abdo
Rana abdo is on a distinguished road
I have a several rough surface geometries how can i adjust y+ for each roughness case
(For each roughness case i have the roughness parameters)
I Know that i have to adjust y+ between 30 to 300 for roughness but which value when i use 30 or 50 or higher i get different results. So which y+ is optimum and i am using the k w sst model ?
Rana abdo is offline   Reply With Quote
Old   November 30, 2023, 23:55
CFDfan is on a distinguished road
I might be wrong but as far as I recall the K-Omega SST requires the Y+ <1, so please verify that
CFDfan is offline   Reply With Quote
Old   December 1, 2023, 02:52
Question
Rana abdo
Even if i use k e model with standard wall function wich y+ value in a range of 30 to 300 should i use for each roughness case on what bases do i choose the y+ value ?
fluent, roughness height, y+ distance from the wall
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
