normal shock keep moving reverse inside intake in supersonic 2 ramp compression intak |
Osama Zahid
Rep Power: 3 ![]() |
I am trying to do a 2D analysis of supersonic intake with 2 ramp angles. the normal shock comes back from the diffuser area to the throat but then continues to move forward when I increase the iteration. using steady, DES with k omega SST. can anyone help in this case. pressure at inlet and outlet are provided. flow is of Mach 2.5
inlet, intake aerodynamics, normal shock, oblique shock, supersonic |
supersonic flow past compression ramp | yapalparvi | OpenFOAM Running, Solving & CFD | 1 | June 14, 2017 12:13 |
Simulation of moving normal shock wave | ROHAN | Main CFD Forum | 1 | May 22, 2016 04:14 |
how can make normal shock in the nozzle at inlet B.C : Pressure Far field | SonicGhoul | FLUENT | 2 | May 8, 2016 06:16 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Will compression waves overtake a moving shock? | GRA | Main CFD Forum | 2 | October 19, 2006 01:24 |
