Periodic channel flow source term implementation
Old   November 22, 2023, 11:21
Default Periodic channel flow source term implementation
Ra1
Ra Khan
Ra1 is on a distinguished road
I have started my undergraduate project in cfd and I want to implement source terms for periodic channel flows with scalar transport. As far as I have read, I found it can be done by implementing a term that leads to a fixed bulk reynolds number in the channel.
I have just started learning CFD (sophomore in college). Can somebody outline the implementation procedure for fixing the bulk Re?
How I think about it is that during every iteration, the flux through the cross section of the channel must be computed and then the target flux (fixed Rebulk) is also computed. Then a correction term given by the difference of the two can lead to a correction for momentum eqn. Is that right?
Can someone put this into mathematical/computational form?
Thanks in advance.
Ra1 is offline   Reply With Quote
Old   November 23, 2023, 06:52
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Ra1 View Post
Thanks in advance.
The dynamic correction based on volumetric flow rate is one of the methods.
Otherwise you set a fixed constant in the momentum equation, as I explained in Sec 5.1 here
https://www.researchgate.net/publica...ection_methods
FMDenaro is online now   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
