Conjugate heat transfer: thin solid
Old   November 15, 2023, 13:32
Default Conjugate heat transfer: thin solid
SMN
mortazavi is on a distinguished road
I am simulating the heat transfer between a flow and thin solid. As you know mesh in the solid is problematic in the case of very thin wall, I can generate only one cell in the thickness direction). I would like to know if there is any way in CFX to treat the interface as a wall, as in Fluent where we can apply the solid properties (thickness and material) on a surface without the solid domain. thanks
mortazavi is offline   Reply With Quote
[Salome] Number of nodes for proper heat transfer in thin solid mm66 OpenFOAM Meshing & Mesh Conversion 0 January 21, 2020 16:10
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Algorithme choosing for solid part analysis of conjugate heat transfer Anna Tian Main CFD Forum 4 January 20, 2013 17:11
Conjugate Heat Transfer in rhoPisoTwinParcelFoam jabecker OpenFOAM 0 June 23, 2011 10:19
