November 9, 2023, 09:51 |
Approximating derivative in 2D finite volume
Matthew
Rep Power: 4 |
Suppose I have a rectangular cell with vertices at , If we label the sides, in the obvious way as . The finite volume method yields the derivatives evaluated at the cell sides, and
I know how to approximate: on the east, and west faces using Taylor series is a simple way. However, I am confused about how to do it on the north, and south sides. I thought about taking averages around the north(or south) edge. |
November 9, 2023, 11:48 |
Matthew
Rep Power: 4 |
November 9, 2023, 12:12 |
Filippo Maria Denaro
Rep Power: 73 |
That depends on the choice you did for the colocation of phi. Is it at the FV center X(i+1/2),Y(j+1/2) or is cell-vertex ?
It seems a cell-center colocation, thus you need of an interpolation. But why do you need a tangential derivative on the faces? In a FV scheme it never enters into the update. |
November 9, 2023, 12:39 |
#4 | |
Matthew
Rep Power: 4 |
November 9, 2023, 13:17 |
Rep Power: 73 |
The normal component of the tensor has tangential derivative ? Then yes, use a linear interpolation.
finite volume method |
Matlab code for Finite Volume Method in 2D | coagmento | Main CFD Forum | 5 | October 7, 2022 13:47 |
The fundamental difference between Finite Difference and Finite Volume Methods | vikramaditya91 | Main CFD Forum | 3 | January 14, 2016 04:13 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
influence of convex or concave control volume in finite volume discretization | openfoammaofnepo | Main CFD Forum | 1 | March 24, 2014 02:13 |
