November 8, 2023, 05:58 |
wind driven flow
Eric Segalerba
Rep Power: 4 |
Hello everyone,
I'm stuck in a problem since a week and I can't figure out how to proceed. I'm trying to simulate a wind driven flow, I have a domain with two phases, water and air, and I apply a constant velocity in the "air" domain. I want to see how water responds to this. Since I only have a patch for inlet (for outlet and so on) I'm using multiphaseEulerFoam, rather than interFoam, to avoid splitting the patches. The problem is... my domain is emptying! The water flows out of the domain and I can't keep it inside in any way.. Does anyone have experienced this or have any clue on how the boundary conditions should be set to prevent this problem? Thank you in advance! |
November 8, 2023, 07:37 |
Filippo Maria Denaro
Rep Power: 73 |
Do you need to describe the wave onset or only the flow driven in water?
November 8, 2023, 07:56 |
Eric Segalerba
Rep Power: 4 |
Hi!
I need to describe the onset |
November 8, 2023, 08:00 |
Rep Power: 73 |
November 8, 2023, 08:03 |
Joern Beilke
Rep Power: 20 |
You need to specity a pressure outlet, where the pressure is a function of the hight of the water p = rho . g . height . This will prevent the water from flowing out.
November 8, 2023, 08:07 |
Eric Segalerba
Rep Power: 4 |
I tried to use prghpressure at the outlet but still the water flows out.. Is there maybe a specific bc for alpha to be set?
November 8, 2023, 08:13 |
Joern Beilke
Rep Power: 20 |
Here is an example from Mr. Peric, how it is done in Comet.
November 8, 2023, 11:07 |
Eric Segalerba
Rep Power: 4 |
Ok I'll try to decode it since I have never used comet ahah
thank you! |
November 8, 2023, 12:41 |
#9 |
Joern Beilke
Rep Power: 20 |
It is likely very similar to the "prghpressure" boundaries :-) I also never used Comet but this user coding is very similar to StarCD.
I never really solved this problem 100%. Usually I ended up splitting the outlet and defining the lower part, which is next to the water as wall. It also worked, when using a normal "Outlet" in StarCCM+. |
multiphase, multiphase bc, multiphaseeulerfoam |
Pressure driven compressible flow between two gas reservoirs | dld | OpenFOAM Running, Solving & CFD | 1 | October 27, 2022 14:45 |
Open channel, Gravity driven flow over and through a porous bed | narendrapatel111 | FLUENT | 0 | June 8, 2020 04:14 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Urban wind flow modelling - formular needed | charltonjames | Main CFD Forum | 0 | September 4, 2009 08:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
