nan found in residuals
Old   November 6, 2023, 10:21
Default nan found in residuals
Eryn
nor nazifah is on a distinguished road
Hye, currently I'm doing my Final Year Project about computational investigation on maneuvering of ship using HEXPRESS & NUMECA FINE MARINE that involve AGR and overset since my project include rudder motion and also ship maneuver. I used C-Wizard parameters setup for seakeeping option. A zmax and zmin was assigned as prescribed pressure while others boundary condition was assigned as far field for the rest of background domain and overset for hull domain.The total meshing of this project is about 10 million. Then, I run a parallel simulation with 10 number of per partition. But, when I run the simulation, the solver is crashed and the error is about 'NaN found in residuals' and something about memory allocation error. So my question is, do we need to use AGR for overset computation ? I really appreciate if anyone have any idea about my problem. Here i attach with the picture of the error.
Attachment 97072
Thank you.
nor nazifah is offline   Reply With Quote
Old   November 6, 2023, 10:44
M
AtoHM is on a distinguished road
This is your third post in 20 min here. This is not a help desk. Edit your own posts if you want to add information to it.
Your simulation diverges, there could be anything wrong. With the given information no one here will be able to help you. Make sure to do the tutorials provided with the software which are closest to the setup you are investigating. Why do you think that increasing the number of cells helps your solver to not diverge?
AtoHM is offline   Reply With Quote
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
