Simulating a Diaphragm with Flow Pressure and Variable Area |
November 1, 2023, 05:41 |
Syed Wajeeh
Rep Power: 4 |
Hey All. I am asked to simulate a geometry in which a fluid exerts pressure on a diaphragm as a result of which the spring (attached to the diaphragm) deflects and the area beneath the spring changes which changes the flow rate. The task is to perform the simulation in such a way as to look for the deflection of the spring, change in the flow-rate , velocity and pressure of the flow all at the same time. Is it possible ?
Need some quick help please. Anticipating for some prompt replies. Thanks in Advance. |
two different gas! Fluid pair model! | saha2122 | CFX | 7 | February 9, 2022 08:15 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 07:00 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
