Reference wind speed Uref in finding wind pressure coefficients on a building facade
Old   October 27, 2023, 12:43
Question Reference wind speed Uref in finding wind pressure coefficients on a building facade
Shadab
Shadab_mdr is on a distinguished road
Hello everyone,
I'm currently working on a CFD analysis to compute wind pressure coefficients (Cp) on a building facade. My objective is to use these Cp values in the BES-AFN tool for evaluating the impact of natural ventilation. While reviewing various studies that have undertaken similar work, I've encountered conflicting information regarding the parameter Uref.
In Eddy3D, a plugin for OpenFoam with the capability to create a cylindrical domain, default values for Uref and Zref are set at 10 m/s and 10m, respectively. Eddy3D doesn't request additional input for the local wind speed. However, some research papers suggest that the dynamic wind pressure (Pd) necessary for Cp calculations should be determined at the building height.
My analysis involves a parametric design, exploring different building heights. So I suppose I need to establish a consistent reference height for all simulations. I've already obtained weather data containing wind speeds and directions and have calculated average wind speeds at a height of 10m for 12 different directions. My question is whether these averaged values should be directly input as boundary conditions or if I should stick with a fixed value for Uref, like the mentioned 10 m/s.
Any guidance to clarify this matter would be greatly appreciated.
Shadab_mdr is offline   Reply With Quote
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
[OpenFOAM.com] An Error in recompiling of openFoam-4.0 alimea OpenFOAM Installation 4 April 8, 2020 15:44
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
