jets- confined /submerged
Old   August 25, 2000, 02:02
Default jets- confined /submerged
Gangopadhyay
Dear Friends:
Can you pl. clarify whar are confined and submerged jets.
how otherwise an impinging jet can be classified?
Old   August 25, 2000, 02:23
Default Re: jets- confined /submerged
John C. Chien
(1). If the jet is fully submerged under the water, it is called submerged jet. In this case, it is not a surface jet, and there is no free surface effect. (2). The jet is confined, if there are walls nearby. This will limit the motion of the fluid. The jet without any walls nearby to limit its motion is called "free jet". Normally, a jet is a free jet. A confined jet can create complex flow recirculation. (3). If there is a wall in front of the jet, it is called impinging jet, because the jet will hit the wall. This is normally done on purpose, for example to heat, or cool the wall.
Old   August 25, 2000, 04:20
Ahmed Hassaneen
In addition to what John said, there is also the Axial impinging jet and radial impinging jet. Each of them has different fluid flow and heat transfer characteristics.
Old   August 25, 2000, 04:46
Bivan
Dr.Chien:
If a high temperature impinging jet(temperature/velocity /pressure are all kdown) sprays into air ,what's its source term in laminar numerical model ?
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 21:18
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR Carl CFX 1 September 25, 2006 10:48
Summer Course on ''Jets in Cross-Flow'' alfredo soldati Main CFD Forum 1 May 5, 2001 22:34
confined jets djemaa Main CFD Forum 10 January 2, 2001 10:29
confined jets hoda Main CFD Forum 2 January 2, 2001 07:47
