October 18, 2023, 06:45 |
Fluid flow around a PDC bit
John Yang
Rep Power: 17 |
Hi, there. No idea where I should put the post.
I'm about to compile a software to simulate the fluid flow around a PDC bit in drilling engineering. Here's what I'm about to do. 1. code the GUI 2. import the bit profile from UG or Solidworks designs with filetype of stp or iges 3. call some opensource code to generate the mesh and setup the boundary conditions and initial conditions, export the mesh 4. call some opensource code to solve the fluid flow and postprocess. My question is, are there any opensource codes I can use to generate the mesh and perform the CFD calculation? Openfoam is not considered right now. for Gmsh, there may be some problems with mesh export. Suggestions are welcome. Thanks in advance. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
UDF profile for a fluid flow through a valve | elia.p | Fluent UDF and Scheme Programming | 0 | May 2, 2017 06:52 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
