Plenum pressure measurement using a probe in OpenFoam
Old   October 15, 2023, 22:43
Default Plenum pressure measurement using a probe in OpenFoam
Niyas
niyas is on a distinguished road
Hello all,
I am currently working on a simulation using OpenFoam version-6, focusing on the geometry illustrated in Figure-1 (attached). Due to limitations in computational resources, I am excluding the plenum chamber from the meshing process. Consequently, the final geometry I'm working with is depicted in Figure-2.
I have a couple of questions regarding this setup:
Plenum-1 Pressure Measurement: If I place a probe (indicated by the black dot) at the inlet patch (highlighted by the thick red line) and measure the pressure, can this value be considered as the plenum-1 pressure?
Throat Pressure Measurement: Similarly, if I position a probe (black dot) at the throat section (marked by the dotted red line) and measure the pressure, can this measurement be regarded as the throat pressure?
I would greatly appreciate any insights.
Thank you in advance.
Regards,
Niyas
niyas is offline   Reply With Quote
chamber, openfoam v6, plenum, probe
In what unit is pressure measured on OpenFOAM? Matheus.Costa OpenFOAM 16 February 23, 2024 05:08
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Reference pressure in OpenFOAM P.Satish OpenFOAM Running, Solving & CFD 7 December 21, 2017 13:01
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
