Question about volume calculation in DPMFoam postprocess |
September 28, 2023, 22:39 |
Jing Zheng
Hello Foamers,
I'm new using OpenFOAM maybe for 3 months, and recently one problem with my DPM case rwas haunting me for a while: I'm simulating some smoke in a room with DPMFoam, the calculation was fine; at the end I need to calculate the volume of the cells which has certain numbers of particles or higher ones ,aka. the volume of smoke which has certain or higher concentration. This PostProcessing-Problem is kinda new to me, also I was trying looking for some useful infomation, and I think the "Function-Object" and "Post-Processing" should be helping, but until now no clear clue was formed. So leave some helps here please, thanks to all! |
concentration, dpmfoam, post process |
Question about Postprocess in DPMFoam | XiaoMan | OpenFOAM Post-Processing | 0 | September 28, 2023 21:18 |
Foam::error::printStack(Foam::Ostream&) in compressibleInterFoam | JM27 | OpenFOAM Running, Solving & CFD | 2 | May 26, 2020 08:13 |
[blockMesh] blockMesh error - Negative Volume Block | adoledin | OpenFOAM Meshing & Mesh Conversion | 2 | June 22, 2016 10:44 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
Flux calculation in vertex-centered finite volume. | Martin | Main CFD Forum | 3 | June 4, 2008 10:04 |
