Super Simple Problem...
Old   September 18, 2023, 01:04
Default Super Simple Problem...
Brett
Bdew8556 is on a distinguished road
hi all,
At the risk of sounding very silly, could anyone help me out with what the 'a' is equal to in these equations:
https://www.youtube.com/watch?app=desktop&v=MNqf8H7hyyc
Many thanks.
Bdew8556 is offline   Reply With Quote
Old   September 18, 2023, 01:11
Lucky
Starting from some grid, you apply FVM and discretization schemes to each cell. For implicit schemes you end up with a linear system of equations that need to be solved. The a's are the coefficients in this linear system, i.e. the elements in the matrix. Your choice of schemes will change the exact value of a's but the general method remains the same. You always get a linear system.
Old   September 18, 2023, 01:14
Brett
Nice! thanks for that. Do you have any easy to understand (as much as is possible) examples?
Old   September 18, 2023, 01:21
Lucky
An easy way to get a feel for it is to look at the classical problems and these are advection or diffusion problems. See for example a 1d and 2d example in Crank-Nicolson. Navier-Stokes is just a teeny bit more complicated with the pressure gradient, which calls for a scheme such as simple, and also having both an advection and diffusion term, which you can imagine is just like summing two matrices.
Old   September 18, 2023, 01:52
Brett
Thanks for that, if you do come across any good illustrated examples let me know.
applied mathematics, momentum, navier
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 17:00
Problem using FVM, SIMPLE algorithm Elay Main CFD Forum 0 July 3, 2014 17:39
very simple problem with interFoam seju OpenFOAM 0 June 10, 2014 06:13
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 10:52
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 07:19
