Best way to calculate bulk fluid temperature in case of steam-water flow |
September 12, 2023, 04:23 |
L S
Rep Power: 10 |
In order to get Heat Transfer Coefficient, I need to calculate bulk fluid temperature at different axial locations in a pipe flow boiling case. But, the getting bulk fluid temperature in two-phase flow doesn't seem straightaway. So, What will be the best strategy?
I am using RPI wall boiling model and post-processing is being done in tecplot. Do I need to do area averaged or mass averaging or other suitable method? how to I combine phase-1 (liquid) and phase-2(vapor) temperatures into one? |
September 13, 2023, 00:33 |
Lucky
Rep Power: 66 |
Bulk temperature is defined as mass averaged
September 13, 2023, 00:41 |
L S
Rep Power: 10 |
okay. Till now I have understood that mass flow averaged has to be considered. But, that can be found for single phase flow. what about two phase flow at cross section? How mass flow averaged temperature formula works for two-phase?
September 13, 2023, 01:33 |
Lucky
Rep Power: 66 |
What happens if you have a glass of water with ice?
Bulk temperature was invented exactly to deal with these kinds of scenarios and yet you are questioning how bulk temperature would work as it was intended. |
September 13, 2023, 02:31 |
L S
Rep Power: 10 |
I just want to know if following formula is correct or not for bulk fluid temperature:
Tb=(Ti ui ρi Ai + Tj uj ρj Aj)/(ui ρi Ai + uj ρj Aj ) ui=velocity of phase 1 ρi = density of phase 1 Ai = area occupied by phase 1 Same notations are for phase 2 with j. Last edited by silviliril; September 13, 2023 at 02:32. Reason: typing correction |
flow boiling, heat flux, heat tranfer coefficient, rpi model, two-phase flow |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 05:46 |
Bulk mean fluid temperature in internal flow | mssound | FLUENT | 0 | May 13, 2010 15:56 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
