Issues with Numerical Ventilation in Free Surface Surfboard Flow |
September 5, 2023, 10:59 |
Vasco Breitenfeld
Hello everyone!
I'm currently undergoing a master thesis in CFD, studying a Surfboard in a non-wave, free-surface scenario. I am having issues with Numerical ventilation, with the lower section of the board being entirely covered by a layer of air that wouldn't be there in reality, this is affecting the entire calculation. I have tried some of the advice in https://strathprints.strath.ac.uk/75...ning_hulls.pdf but none have worked so far both with low and high y+ treatments. The problem seems to arise due to geometry, where a recirculation zone happens below the nose of the board and above the free surface line, which the solver cannot resolve. To worsen matters, I am using a code that does not allow me to ramp up velocity in the domain, meaning I have to start every element at 6m/s, the desired speed for my surfboard. Does anyone have any experience of how to solve this situation? If so your help would be truly appreciated! The images attached show the initial conditions, as well as a picture of a time step where the air layer is already forming. Thank you, Vasco |
September 5, 2023, 14:22 |
#2 | |
Arjun
Rep Power: 34 |
Start with a very very small time steps and slowly ramp them. The main issue is that in the start the pressure field is not correct and thus forces are wrong. You might end up in unphysical situations. Increase slowly the time step when the pressure field start to make sense. |
September 6, 2023, 05:55 |
#3 | |
Vasco Breitenfeld
So the recommendation is for me to start with a small velocity and time-step and slowly ramp them up, meeting the CFL = 1 condition. I am also using second-order time discretization, I think this is the way to go to help with this problem. My time step is currently on the order of 1e-4 s Edit: I am also using wall functions, but my code supports a Contact line correction option. |
September 6, 2023, 16:06 |
mauricio
Rep Power: 18 |
also check domain resolution.. your mesh seems a bit coarse for your board.. sometimes you don't need to resolve some features of the flow but you might be forced into it not to bump into nonphysical results, convergence issues and ultimately the crash of the model.
Best Regards /calim "Elune will grant us the strength" |
cfd master thesis, free-surface flow, numerical ventilation, surfboard geometry, surfboard simulation |
Free surface sensitivity - drag coefficient & mesh sizes | SYL | Main CFD Forum | 1 | May 15, 2023 11:53 |
Free surface flow in 3D lectangular channel | pygmi | FLUENT | 0 | January 18, 2016 06:48 |
Free Surface flow? | silvia_petkova | CFX | 1 | June 2, 2010 16:33 |
free surface flow same as FSI??? | Ken | CFX | 1 | February 18, 2008 19:43 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 06:27 |
