Gas Irradiation
Old   August 31, 2023, 12:14
Default Gas Irradiation
Andrew
mettler is on a distinguished road
Hi -
I am trying to model gas irradiation for a laser. In my head I am picturing something very similar to a PIV system except the beads get super hot. I have a extremely tiny concentration of the atoms that are radiated that does not have any impact of the Cp/density etc of the main gas. The amount of time the gas is in front of the window where there LED light comes in is extremely small, but the radiation causes a very rapid heat up of the atom. I am thinking of using porous media to model it, but I am having some trouble coming up with the variables needed for the porous media flow since the porosity would be almost 1100%, and how to apply the input power to only the porous media. I don't think I can use a heat flux at the wall, since the atoms are all over the place but not at the wall at all.
I am interested in how much the gas heats up as a result of the irradiation. If anyone has another suggestion in how to model this, please let me know.
mettler is offline   Reply With Quote
Old   September 1, 2023, 09:59
Lucky
If all you care about is the temperature of the resulting gas then a simple volumetric heat source will do. The power of this heat source you can calculate with a napkin using the beam energy or intensity and absorption cross section of the particles.
Old   September 1, 2023, 10:22
Andrew
Thanks. That is a good idea, but I’m not sure if that would replicate what is going on. I do know the power input from the LEDs but the irradiated atom concentration in the gas is .000001, and those atoms are the only thing getting hot. The lab experiment shows about a 100k temp rise across the window.
I’ll try the volumetric case. When I did the steady-state temp rise calc I got roughly 100k, so maybe the volumetric way will work.
Thanks.
Old   September 28, 2023, 14:21
Andrew
I was able to do a great 2d model, but I can't get the volumetric heat source to work in 3d. I am only getting a very hot wall. I made a zone of the correct volume and applied a volumetric heat rate in the source. Any suggestions of what I missed would be appreciated.
thanks
irradiation, porous
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
