#161 | |
Matthew
Rep Power: 4 ![]() |
#162 |
Matthew
As you can see a lot of the issues I've had have gone away after my rather crude fix the issue at h=0 is now working. The issue is now twofold: The value at h=1 seems to be erratic. I use a stress-free condition at h=1, but there still seems to be a spike.
The other issue is about parametrisation. |
#163 |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
How do you introduce the Neumann BC into the scheme?
#164 |
Matthew
#165 |
#166 | |
Matthew
This is graph is for the edges, rather than the cells. I used interp1 in Matlab to obtain the values, and I got a NaN at h=0 for some reason. |
#167 |
Matthew
I have the majority of the problems sorted but one issue I think is the length of the rod in question. The way I calculate it is by using the mass in each cell as being constant. and if dh represents the mass of a typical cell, then I use:
![]() where dX represents the new length after compression. The new cell locations are then given as Code:
X=[0 cumsum(dX)] As you can see, it hasn't gone down much and I wondered if this was the code or just a poor choice of parameters. |
finite volume method |
multiphaseEulerFoam FOAM FATAL IO ERROR | qutadah.r | OpenFOAM Running, Solving & CFD | 11 | December 10, 2021 20:18 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Gradient evaluation in Finite Volume Methods | yidongxia | Main CFD Forum | 7 | August 6, 2012 10:23 |
Unstructured grid finite volume methods | Marcus | Main CFD Forum | 3 | December 5, 2000 00:25 |
