August 1, 2023, 02:49 |
Ablation Simulation Software Needed
Daniel
Rep Power: 8 |
Hi all,
Please is there anyone in the house that can assist me with a good CFD Software? I am trying to simulate cold flow over a hot surface of an Apollo/Orion heatshield but using a prototype of 50 millimetres in diameter. I have tried some couple of software but all efforts proved abortive. Here are some limitations: ANSYS does not give a good precision of the surface recession that is associated with ablation species; OPENFOAM seems to be hectic and some open packages are missing for thermo-physics and surface recession; SimFlow cannot perform ablation studies; Eilmer cannot perform ablation studies; I do not have access to many other ablation software used by NASA and ESA because I am not an American citizen. Please see attachment for the physical explanations. Any suggestion will be highly appreciated. Even if I am buying a software, it should not be too expensive because it is for my personal research and academic purpose. Thank you. |
August 1, 2023, 04:15 |
Arjun
Rep Power: 34 |
What do you mean by surface recession here? The material will be removed and surface goes back. Is this correct?
August 1, 2023, 07:45 |
Daniel
Rep Power: 8 |
Yeah you're absolutely correct. Materials removed and surface goes back, leading to a decreased thickness.
Best software for centrifugal fan (rotating geometry) simulation | DRoam | Main CFD Forum | 0 | November 18, 2016 16:12 |
Third party software in Aeroacoustic simulation | Henry Arrigo | STAR-CCM+ | 1 | July 15, 2014 11:31 |
Mesh generation software is needed | H.Dou | Main CFD Forum | 12 | May 4, 2011 15:20 |
Recommended software for heat sink simulation | nahmed | ANSYS | 5 | October 27, 2010 09:49 |
which software best for simulation of propulsion | hanman | CFX | 4 | August 27, 2008 13:29 |
