Calculating energy dissipation rate from power spectrum |
July 26, 2023, 11:57 |
Rep Power: 3 |
July 26, 2023, 12:25 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
k=n*2*pi/L, n=0 corresponds to the constant mean value. However, you have no contribution to the dissipation |
July 26, 2023, 13:17 |
#3 | |
Rep Power: 3 |
My criterion is that the total cumulative dissipation divided by needs to be very close to 100% (this typically happens by the time reaches around 2). However, the starting value of the integral impacts whether the total cumulative dissipation divided by is close to 100%. is a constant in the dissipation function () portion of the Pope model (Eqn. 6.248 in Pope's book), which according to Pope is determined by the criterion that the equation I posted needs to integrate to , which I believe means that the cumulative dissipation divided by determined by the numerical integration is equal to 100%. So, for example, if the large eddy size (L) is substituted for 0 in the integral, then if L is equal to 344 microns, = 0.03785 and = 0.415, which is very close to Pope's value of 0.4 at high Reynolds number. But if L is equal to 22 microns, then has to be equal to 0.55, in order for the criteria that the cumulative dissipation divided by equals 100% at high values of . Ultimately I'm trying to plot the cumulative dissipation divided by versus to determine what the cumulative dissipation value is at a certain value of . So, for the 2nd example (L = 22 microns) shouldn't a specific value of (say 0.5) have a higher cumulative dissipation divided by than the first example (where L = 344 microns) at = 0.5? |
July 26, 2023, 13:30 |
Rep Power: 73 |
The integral lenght of order of microns? Are you sure that is meaningful of a turbulent flow? In microfluidics you have to consider also other effects. I dont know if the exercise of Pope makes sense at such a low scale. |
July 26, 2023, 13:57 |
Rep Power: 3 |
I don't see why it wouldn't. The equation given by Pope models the energy spectrum to at least the Kolmogorov microscale. For the two examples I gave, the Kolmogorov microscale is 2 microns and 0.7 microns respectively. Admittedly not fully developed turbulence but it should work I would think.
July 26, 2023, 14:04 |
#6 | |
Rep Power: 73 |
Ok, but the Taylor microscale, that defines the onset of the dissipation region, is larger, I doubt you have some fundamental characteristic of turbulence like an inertial range. |
July 26, 2023, 14:32 |
#7 | |
Rep Power: 3 |
One other note: My system is decaying turbulence but some of the data shown in Fig. 6.14 in Pope's book is for grid turbulence (Taylor Reynolds numbers varying from 37 to 540). So back to my original question: Should the lower bound of the integral be equal to zero or equal to L (examples of 344 microns and 22 microns)? Last edited by rdemyan; July 26, 2023 at 14:34. Reason: Add an additional note |
July 26, 2023, 14:46 |
#8 | |
Rep Power: 73 |
If you see the figure 6.14, the spectra at Re_lambda=36 (BL flow) shows practically no inertial range. The dissipation range starts after few symbols. Pope wrote often "for high Reynolds flow" to highlight that fact that in turbulence you have a range of inertial transfer energy (that is almost inviscid). Your flow problems has an integral scale that is practically also the Taylor microscale. And, being your problem in decaying condition, the range will be totally dissipating. |
July 26, 2023, 14:55 |
#9 |
Rep Power: 73 |
Integration is performed from k=0, fig. 6.16. Try to plot your dissipation spectra.
July 26, 2023, 14:58 |
#10 | |
Rep Power: 3 |
Sorry, I didn't see your post just above. Last edited by rdemyan; July 26, 2023 at 14:58. Reason: Update |
July 26, 2023, 15:06 |
#11 | |
Rep Power: 73 |
I suppose the fit cna somehow work but is not really meaningful at such a low Re number. Try to replicate the computation of the energy spectra and dissipative spectra. I am curious to see if you can get a relevant difference between the integral lenght and the Taylor microscale. The integral starts always from k=0. |
July 26, 2023, 15:10 |
#12 | |
Rep Power: 3 |
Yes, Fig. 6.16, the dissipation spectrum, is what I am using as a guide. The problem is that if I start from k = 0, there is virtually no difference between my two examples. As I think about it some more, that probably makes sense. Fig. 6.14 shows that all of the 17 models converge once the dissipation range is reached. It's only at lower values of that there is a difference between the 17 systems. So, that would seem to suggest that Fig. 6.16, the dissipation spectra, is pretty accurate for all of the 17 systems shown in Fig. 6.14. Would you agree with that? But, why does Pope say that the coefficient, , needs to be changed from the high Re value of 0.4 based on 100% cumulative dissipation equaling the energy dissipation rate? |
July 26, 2023, 15:32 |
#13 |
Rep Power: 73 |
The fact you see no differences in your two cases should confirm you are working at a very low Re number. I don't have now in mind that part of the Pope discussion, however he showed the case at high Re number 600. |
July 26, 2023, 20:45 |
#14 |
Lucky
Rep Power: 66 |
6.256 uses a model valid only in the dissipative range (i.e. infinite reynolds number). Why are you are not at least using 6.246 if you want to see what happens at lower ranges?
Any model function you use for the dissipation spectra must satisfy integrated from 0 to infinity. This comes from the definition of turbulent dissipation rate which also results in the contribution at exactly 0 frequency to be 0. So technically you can start integrated at some infinitesimal start at 0+dk. Infinitesimally small is not equivalent to arbitrarily large. They are quite opposite. |
July 26, 2023, 21:34 |
#15 | |
Rep Power: 3 |
July 27, 2023, 09:09 |
#16 |
Lucky
Rep Power: 66 |
If dissipative scales are your fetish then feel free to indulge
But then you should not expect that integrating a subset of the spectra matches the mean in a universal way especially considering that the largest scales are the least universal amongst scales. In other words, you not only know that integrating from L to infinity cannot add up to 100%, it must add up to less by a function that is Reynolds number dependent. You need a new criteria |
July 27, 2023, 21:37 |
#17 | |
Rep Power: 3 |
July 28, 2023, 01:35 |
#18 |
Lucky
Rep Power: 66 |
Yes you have discovered the concept of separation of scales in turbulent flows, which increases with increasing Reynolds number. You can imagine that at low enough Re when you become wholly laminar and you have only dissipative scales.
Btw your E(k) is assuming local isotropy and isn't actually more general than E11. |
July 28, 2023, 05:12 |
#19 |
Rep Power: 73 |
Some observations: 1) the inertial range in the energy spectra is also more extended than I expected. Note that the slope -5/3 in the dissipation range has no meaning as term of comparison. 2) The model dissipation spectra in Pope shows a clear exponential decay, your figure seems different, that should be the effect of the too low Re number. 3) You wrote you are working on a decadying turbulence, that means you do not have an energy equilibrium state. Energy and dissipation spectra will change during the decaying. |
July 28, 2023, 11:28 |
#20 | |
Rep Power: 3 |
@LuckyTran: The reason I am interested in the dissipation spectra is because the size of the micromixing scale appears to be a function of this time lag. The longer the time lag the more time available for the scales to be "ground down". The micromixing scale appears to be a function of the cumulative dissipation, which cumulative dissipation I am calculating by using Pope's model. Also, I was comparing the values of E(K) with E11(K) and according to Pope's Fig. 6.11, there is a difference. I just wanted to see if the values shown on my charts were in the right ball park for the Reynolds numbers (which they appear to be). Last edited by rdemyan; July 28, 2023 at 11:33. Reason: Additional info |
Constant Residual of Turbulence Kinetic Energy and Dissipation Rate | wrightguy | FLUENT | 4 | June 20, 2021 11:19 |
Energy spectrum in frequency | bhigahAshish | Main CFD Forum | 4 | July 7, 2019 11:54 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
calculation of (turbulent) dissipation energy ? | max | Main CFD Forum | 3 | August 18, 1999 10:42 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 14:22 |
