Backward Euler comprised with upwinding of viscous Burger's equation |
July 14, 2023, 07:01 |
Matthew
Rep Power: 4 |
In order to build up solving a coupled set of equations, I was going to solve the viscous Burger's equation:
u_t+uu_x=Dy_xx along with the boundary conditions u(t,0)=0, and u_x(t,1)=0. I have had some success with the backward Euler method as being unconditionally stable, and I understand that I need to upwind. I wrote te following code: Code:
%This is to test the method of solution of a ODE via Newton-Raphson method. clear;clc; M=3000; N=200; D=0.1; x=linspace(0,1,N); %x-axis variables t=linspace(0,20,M); dx=abs(x(2)-x(1)); dt=t(2); a=dt/dx; b=D*dt/(dx^2); u=zeros(M,N); %Solution variables; u_0=exp(-25*(x-0.5).^2); u(1,:)=u_0; y_old=u_0; tol=1e-6; %Compute the solution for i=2:M y_old=u(i-1,:); y_test=u(i-1,:)'; r=Newton(tol,a,b,y_old,y_test); u(i,:)=r'; end for i=1:2 plot(x,u(i,:)); pause(0.1); end function [J] = jacobian(a,b,y_old,y) % Computes the Jacobian matrix of the function f(x) % f: function handle that returns a vector of function values % x: column vector of independent variables % Number of function values and independent variables n = length(y); % number of independent variables % Initialize Jacobian matrix eps=1e-5; % could be made better J = zeros(n,n); T=zeros(n,1); for i=1:n T(i)=1; fPlus = vb(a,b,y_old,y+eps*T); fMinus = vb(a,b,y_old,y-eps*T); J(:,i) = (fPlus-fMinus)/(2*eps); T(i)=0; end end % Define the Modified Newton-Raphson method function y = Newton(tol,a,b,y_old,y0) iter = 0; maxiter = 10; error=10; while (error > tol) && (iter < maxiter) J0 = jacobian(a,b,y_old,y0); delta_y = -vb(a,b,y_old,y0)'/J0; y_new = y0 + delta_y'; y0 = y_new; error=norm(vb(a,b,y_old, y0)); iter = iter + 1; end y=y0; end function z=vb(a,b,y_old,y) N=length(y); z=zeros(N,1); for i=2:N-1 z(i)=y(i)-y_old(i)+a*y(i)*(y(i+1)-y(i))-b*(y(i+1)-2*y(i)+y(i-1)); end %Use the boundary conditions z(1)=y(1); z(N)=y(N)-y_old(N)-b*(y(N-1)-y(N)); end |
July 14, 2023, 09:30 |
Matthew
Rep Power: 4 |
The issue here was the size of b was too large. I reduced the size and I got a beautiful solution which does all the funky things that it should do.
I'm curious as I thought the backward Euler was supposed to be unconditionally convergent? What's going on here? |
July 14, 2023, 09:39 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
The velocity is always negative? a*y(i)*(y(i+1)-y(i)) |
July 14, 2023, 10:02 |
Matthew
Rep Power: 4 |
Yes, the velocity is always negative. This is part of a model that deals with a compressible rod essentially. The compression is due to temperature and will always be towards the fixed end. the length, L, of the rod is given by dL/dt=v(t,N). For the length of the rod to decrease, the velocity must be negative.
I thought that backward Euler was unconditionally convergent? |
July 14, 2023, 10:08 |
#5 | |
Rep Power: 73 |
Why do you use Newton method? I don’t understand the implicit part. |
July 14, 2023, 10:51 |
#6 | |
Matthew
Rep Power: 4 |
I use Newton-Raphson because it's the only technique I know of that I can use to solve a set of nonlinear algebraic equations. |
July 14, 2023, 11:25 |
#7 | |
Rep Power: 73 |
there is no mass in your equation, you are solving a parabolic PDE (or perturbed hyperbolic for small values of D) and you MUST prescribe the correct mathematical BCs to have a well-posed problem. If you think that that the assumption of no-inflow and no-outflow is acceptable, use periodic conditions or set u(0,t)=u(1,t)=0. Otherwise your problem is wrong. Now, about the implicit scheme, I suppose you solve u(i,n+1)=u(i,n)-u(i,n+1)*(dt/dx)*(u(i+1,n+1)-u(i,n+1)) + +D*dt/(dx^2)*(u(i+1,n+1)-2*u(i,n+1)+u(i-1,n+1)) right? Generally, the equation is linearized, in your case you have a first order accurate scheme, therefore in the CFL number you can set u(i,n+1)=u(i,n) and solve the linear algebric system. However, this non-conservative scheme is not the best to use. |
July 14, 2023, 12:07 |
#8 | |
Matthew
Rep Power: 4 |
So you're saying u(i,n+1)=u(i,n)+du, and obtain a matrix for du? |
July 14, 2023, 12:34 |
#9 | |
Rep Power: 73 |
July 14, 2023, 12:40 |
#10 |
Matthew
Rep Power: 4 |
July 14, 2023, 13:39 |
#11 | |
Rep Power: 73 |
It depends on how you perform the iteration. The system becomes linear, you could suppose to develop a sort of Jacobi or Gauss-Seidel like iteration. Of course, if you want a greater accuracy in time, the backward time-integration must be improved. Your integration drives the solution to the rest condition? |
July 14, 2023, 13:56 |
#12 | |
Matthew
Rep Power: 4 |
F_j(u_{n+1},u_n)=0 Then I would define my linearization as: F_j(u_n,u_n)+dF_j/du×du=0 This a now a linear system that I can solve using matlabs linear equation solver. I compute u_{n+1} by adding du to u_n. |
July 14, 2023, 14:19 |
#13 | |
Rep Power: 73 |
In your specific case: u(i,n+1)=u(i,n)+dt*du/dt|(i,n)+... du/dt(i,n)= -u(i,n)*du/dx|(i,n)+D* d2u/dx^2|(i,n) but due to the poor time accuracy, I would start by simply setting the convective term in the form u(i,n)*(u(i+1,n+1)-u(i,n+1))/dx without further term. But are you sure the velocity is always negative and the node i=1 remains at u=0? |
July 17, 2023, 12:50 |
#14 | |
Matthew
Rep Power: 4 |
July 17, 2023, 13:01 |
#15 | |
Rep Power: 73 |
I am not sure to understand, I never worked on this kind of problem, you are saying that in your problem the u variable is the vertical velocity? Check the textbook of LeVeque, I remember (if I am not wrong) that a similar problem is detailed. |
July 17, 2023, 15:33 |
#16 |
Matthew
Rep Power: 4 |
I'm aware of the example but it's different to the problem I'm studying as it isn't the same, there are some very important differences such as a variable domain for one. Diffusion of the material is another.
backward euler, upwinding |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
viscous term in energy equation | seb62 | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 03:41 |
Euler ~Navier Stokes equation | Khan | Main CFD Forum | 1 | September 9, 2006 03:26 |
