Inlet velocity becomes entire domain velocity |
July 4, 2023, 12:34 |
Tarık Yaman
Rep Power: 4 |
I was working on 2-way fsi analysis. I am trying to simulate the model in figure-1 (google drive). I wanted to validate the results in section 3.1.2 of the article titled "Computation of fluid–structure interaction on lightweight structures". However, I am getting an error due to a sudden pressure effect on the plate. Looking at the contours, I thought it would be because the inlet velocity was suddenly the velocity of the entire domain. To eliminate this situation, I set the inlet velocity to 0 for the first 5 time steps and 1 m/s for the next steps. I set up another analysis to try the results and again faced the same issue. I want the flow to travel a distance that will be proportional to the velocity value from the inlet to the outlet. For example, if my inlet velocity is 1m/s, after 0.1 second I want the flow to move 0.1 meters. Is this possible? You can access all settings and contour pictures from the link : https://drive.google.com/drive/folde...ER?usp=sharing Thanks for be interested. |
initialization, inlet velocity, patch, transient |
Atmospheric BCs for domain with a single boundary serving as both the inlet & outlet | Newtonian | OpenFOAM Running, Solving & CFD | 0 | July 21, 2022 14:07 |
Making fluid velocity zero in the inlet of domain | nived | FLUENT | 4 | May 28, 2018 09:40 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
patching velocity profile to the inlet face of domain | vasuaero1988 | Fluent UDF and Scheme Programming | 1 | September 29, 2010 03:49 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
