Boundary Conditions for lid-driven cavity
Old   July 3, 2023, 13:14
Default Boundary Conditions for lid-driven cavity
user2296 is on a distinguished road
does someone know the boundary conditions for the turbulence model of Spalart-Allmaras (SA) for a lid-driven cavity boundary value problem? I did not find any thesis or paper where it is explained.
In general, the variable of the SA equation is set to zero at walls and three up to five times the kinematic viscosity at the inlet. Therefore, I wonder if I must set the variable of the SA to zero or not.
Thank you
user2296 is offline   Reply With Quote
Old   July 4, 2023, 16:56
Lucky
You don't find publications because it is an art, not a science. The 5 times viscosity corresponds to the very very very turbulent inflow. If you want a laminar inflow then you want to set it to 0. Except some implementations are unstable with a 0 nutilda inlet and you must specify a slightly positive number that isn't zero that stays laminar and doesn't blow up. Now because it is an art, make sure you also don't tell anyone else what number you used XD.
LuckyTran is online now   Reply With Quote
Old   July 10, 2023, 06:15
Thanks for your answer, it was very helpful
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
