Ruggiero Guida
Rep Power: 13 ![]() |
Is there any equivalent of OpenFOAM for LBM? With equivalent I mean:
I have found a couple online:
But before diving in them I was wondering whether there was a popular one like OpenFOAM. Thanks! |
Tom-Robin Teschner
Rep Power: 16 ![]() |
I think palabos is probably one of the more known / complete ones, though it doesn't tick all the boxes you have asked for. I don't think you will find anything remotely similar to openfoam which focuses just on lbm, unless you remove open source, there are some decent commercial solver availabe (power flow, m-star cfd)
cfd.university |
Ruggiero Guida
Thanks. A bit too much coding required, but interesting nevertheless.
#4 | |
Luis VL
Rep Power: 4 ![]() |
I have tested both FluidX3D and OpenLB and I find OpenLB to be a much more serious project, you have a forum to ask questions, a guide in pdf format where they explain a lot of things, a lot of pre-made examples for different physical cases (with explanations in the pdf I just mentioned), while FluidX3D has only a bunch of examples without any explanation, also the fact that you can export the data from OpenLB to Paraview is extremely useful, in FluidX3D you cannot export any of the calculated data. Btw, check this link, you'll find a lot of LBM open source codes with a little summary of them (notice FluidX3D is not mentioned there). Hope it helps! |
Ruggiero Guida
OpenLB does look promising indeed.
Thank you very much! |
lbm |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 15:16 |
DEFINE_GRID_MOTION equivalent in openFOAM or other free CFD | pdudley | Main CFD Forum | 1 | August 23, 2015 00:06 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 21:07 |
