Compressible flow
Like Tree2Likes
Old   June 25, 2023, 11:42
Matthew
hunt_mat is on a distinguished road
Originally Posted by FMDenaro View Post
Your system can be written like
u^n+1 = T.u^n
Where u is the state vector.
If you do the stability analysis on the eigenvalues of T you will be able to understand that the CFL is not the only parameter to check.
I'm seeing that. I'll do the stability analysis to see if I can't get an answer.
hunt_mat is offline   Reply With Quote
Old   June 25, 2023, 12:11
Lucky
Sure, it is a system of equations with a trivial method to solve it. I just wanted to make sure whether you have a system like Ax=B (this to me is a linear system of equations) or a system like X=C (this to me is an assignment operation).
I don't know elastic beams well enough to know whether your Peclet number is greater or less than 1. But for high Peclet numbers I don't recommend forward differencing on advection terms (this is downwinding). I would recommend central differencing or backward differencing (backwinding) unless you have Peclet number around 0.
Central differencing on the diffusion terms is reasonable. As hinted earlier, for Peclet numbers not greater than 1, diffusion terms are unstable with Fourier number.
Have you considered debugging on a trivial case? I.e. homogeneous BCs, zero U, and showing that you recover the expected solution and that there is no silly typo? This test case would also be helpful since you can arbitraily coarsen your grid to make the problem more stable to find such bugs.
Old   June 26, 2023, 07:39
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Could you show the analytical solution you have?
FMDenaro is online now   Reply With Quote
Old   July 3, 2023, 10:47
Matthew
I am now examining stability conditions using the Lax equivalence theorem and I am getting some difficult conditions that don't seem to be consistent which is very worrying.
I've included the beginning of my analysis.
Old   July 3, 2023, 12:55
Matthew
An operator A is called linear if and only if A(au+bv)=aAu+bAv, the operators in my original equations satisfy this condition.
I'm currently trying to derive such conditions through a stability analysis using the Lax equivalence theorem. I do not have an analytical solution, it would have to be through a Fourier series. You can't do a separation of variables in this case as the system is coupled. I think that even looking for an analytical solution may be difficult. I could look for the case for a constant temperature, this would still be physically realistic and the analytical solution might be easier to obtain.
Old   July 3, 2023, 12:56
Matthew
I don't have one.
Old   July 4, 2023, 16:24
Lucky
Look man, we all know this is a linearized form of a more complex set of governing equations. I would hope that your linearized system is indeed linear. From the start I've made it clear that I was asking whether you have an implicit system of algebraic equations that need to be solved using gaussian elimination or if you have an explicit time-marching scheme. Anyway, thank you for confirming that you have both.
a5/a4 is your Peclet number
Old   July 4, 2023, 17:04
But have you dobe first the stability analsyis for the case of a single equation of convection-diffusion-production ?
Old   July 5, 2023, 06:32
Matthew
It wasn't linearised from any set of equations, I simply wrote it as a linear system that has all the problems of the nonlinear system that I was working on. I have looked at this from several perspectives: 1) Using the backward Euler method, this should be unconditionally stable, it wasn't. So then I did the simple solution, forward Euler method, I have such stencils in the pdf I attached in a previous post. Nothing seems to be working. I have done a stability analysis using the norm of the matrix being less than 1, and I have gotten some problems with this as I cannot get a consistent set of conditions.
I'm begnning to lean on my original was inconsistent.
Old   July 5, 2023, 07:48
Matthew
I did do a stability analysis, I found that if c=Udt/dx, and a=Ddt/dx^2, then I have the following conditions:
a>c and a<1/2 gave a stable solution along with c>a and a<1.
I found this out by examining the norm of the matrix and setting it to be less than 1 for stability.
Old   July 5, 2023, 09:04
No, first you have to consider also the production term, then is better you do then von Neumann analysis and evaluate the full stability regions (it is an isosurface T |G|=1 in a 3D space.
Old   July 5, 2023, 10:37
Matthew
Why do you think using the Lax equivalency theorem is wrong in this situation?
Old   July 5, 2023, 11:10
Lax equivalent theorem is valid. The issue is that you have to prove the stability.
Consider that single equation, you have
df/dt+u*df/fx=d*d^2 f/dx2 + k*f
The stability region is obtained as the isosurface:
|G|(cfl, Re_h, gamma)=1
G being the amplification factor of the scheme.
That is you have a functional relation between the various parameters.
Old   July 5, 2023, 12:20
Matthew
von Neumann stability analysis isn't always the easiest thing to do.
Old   July 5, 2023, 12:25
Are you kidding?? It is the MUST in any numerical study! Or is a fundamental topic in a CFD course.
For a single 1d equation is very very easy to do using matlab or maple software, just few lines of code.
See https://www.researchgate.net/publica...tion_Equations
Old   July 5, 2023, 13:18
Matthew
Code? All the stability analysis I've seen has been done algebraically.
Old   July 5, 2023, 13:33
In order to generate the practical 3d map for the 1d equation, you have to investigate the most critical frequency for each value of CFL, Re_h and gamma.
Indeed, the complex amplification factor depends on 4 independent variables. Are you able to generate that algebrically ? Let us see …
Old   July 5, 2023, 13:42
Matthew
In the 1D cases I've seen, the von Neuman stability analysis reveals an inequality on the parameters involved in the stencil. I don't know what you're talking about, the type of stability analysis I'm using is setting v_{n,m}=e^{a*n*dt}e^{i*b*m*dx} and looking for the condition for |e^{a*dt}|^{2}<1.
Old   July 5, 2023, 13:57
No, not this way. Let me consider a simple FTUS scheme
f(i,n+1)=f(i,n)-cfl*[f(i,n)-f(i-1,n)]+(cfl/Re_h)*[f(i+1,n)-2*f(i,n)+f(i-1,n)]+gamma*f(i,n)
cfl=u*dt/h, Re_h=u*h/ni, gamma=dt*k
That is
f(i,n+1)=[1-cfl-2*(cfl/Re_h)+gamma]*f(i,n) +[cfl+(cfl/Re_h)]f(i-1,n)+(cfl/Re_h)*f(i+1,n)
Hence
G=[1-cfl-2*(cfl/Re_h)+gamma]+[cfl+(cfl/Re_h)]*exp(-i*k*h)+(cfl/Re_h)*exp(-i*k*h)
From this expression you evaluate the expression for the modulus |G|(cfl,Re_h,gamma,k*h)
so that you can simply code the research for all -pi<=k*h<=+pi for the most critical value of |G| at values clf,Re_h,gamma.
That can be easily done by saving the max value of |G| in a 3d matrix and then extracting the isosurface at |G|max=1 value. Slices can help to see the 2D maps.
Very easy to code.
Old   July 5, 2023, 16:08
Matthew
That is
Hence
Very easy to code.
Then I think we're talking about different things. Could you give me a link regarding the stability you're talking about?
1dfluid, cfd
Compressible nozzle flow - no problem for fluent but impossible with openFOAM? flar.t OpenFOAM Running, Solving & CFD 10 March 30, 2022 02:21
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 01:13
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 14:16
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 14:19
