Extracting flow parameters from measured velocity profiles in wind tunnel
Old   June 15, 2023, 23:23
Post Extracting flow parameters from measured velocity profiles in wind tunnel
Manos Dimitriadis
Manosd25 is on a distinguished road
I have some data simulating different types of ABL in a wind tunnel. The data are basically different velocities (u) at different height levels of the wind tunnel (y), with also known parameters to have the kinematic viscosity (v) and von Karman constant (κ).
I want to extract as many significant flow parameters as possible in order to draw conclusions about how certain profiles would fit in my velocity profiles given the specific circumstances of each flow flowing through my set-ups (with different roughness elements - hence roughness)
The question is how I can find some basic flow parameters like:
- displacement thickness δ*
- momentum thickness θ (would be useful to find also after the Reθ)
- boundary layer δ (not in all measurements the velocity u of the highest possible height is near u99 - so not obvious)
in order to use them afterward accordingly?
I know the formulas of the above parameters but I am not sure of how to find them based on my data.
Thanks in advance.
Manosd25 is offline   Reply With Quote
abl, data, experimental, flow parameters, simulation
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 12:25
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 12:19
Flow simulation in wind tunnel mukut OpenFOAM 15 September 11, 2013 23:43
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
