June 15, 2023, 13:03 |
Meshing with SALOME in parallel
Rep Power: 9 |
Hello Everyone,
I am trying to figure out if there is a chance to mesh with SALOME in parallel. Any suggestion? Thank you! |
July 27, 2023, 09:43 |
Any updates?
Hello, Simone!
I am having the same issue at the moment. Did you manage to find a solution and run Salome in parallel? |
mesh, parallel calculation, salome |
[snappyHexMesh] Parallel meshing - SnappyHexMesh | Akanksha90 | OpenFOAM Meshing & Mesh Conversion | 3 | March 3, 2022 07:52 |
Salome meshing - Algorithm Gmsh | FM_Stiral | Mesh Generation & Pre-Processing | 1 | September 19, 2019 16:42 |
SALOME Meshing 3D extrusion | FM_Stiral | Mesh Generation & Pre-Processing | 0 | July 24, 2019 09:46 |
[Salome] Meshing a STL File in Salome | Fool | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2018 09:39 |
Parallel meshing using XP64 with PVM in CFX Mesh | Huw | ANSYS Meshing & Geometry | 4 | July 12, 2010 10:24 |
