How to Model Pipe Inside A Pipe
Old   June 6, 2023, 11:00
Default How to Model Pipe Inside A Pipe
Agung
limowaagung11 is on a distinguished road
hi i have a design model quite a complex model about a ventilation duct inside a tunnel, I've made the model on CAD and imported it as IGS file in design modeler and have tried to simulate it on Ansys but the problem is the air is not flowing through the duct but otherwise it flow out (it makes no air flow inside the duct). I've imported duct as slice material, add frozen (It makes air didnt flow out from the duct), add material (similar case with add frozen).
limowaagung11 is offline   Reply With Quote
Old   June 7, 2023, 05:09
Sam
__sam__ is on a distinguished road
First of all, your question is a bit vague, you might want to provide a diagram or explain the problem in more detail. Some questions you might want to ask yourself:
So do you have air volume inside your duct? If the duct is a closed, it will be modelled as a solid obstacle so make sure to check it's open so the mesher can place cells inside.
If you have mesh cells present inside the duct, have you checked how many cells it has been discretised with? If it's not got boundary layer cells and has a small number of large cells, it probably won't get flow through it because it's going to be seen as highly resistant due the domination of viscous forces.
How big is your duct? If it's a very small opening, it wouldn't surprise me that there is very little flow going through it as it may be highly resistant - you may need a fan inside to create a good enough pressure gradient.
__sam__ is offline   Reply With Quote
cfd, flow 3d, pipe, ventilation
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Flux inside a pipe of a fluid with a solute Jose Manuel Olmos OpenFOAM Running, Solving & CFD 0 March 17, 2021 19:05
Inside pipe wall temperature rise time t=? tibor Autodesk Simulation CFD 5 September 22, 2017 18:50
How to model a mechanical valve in a pipe? hoyin FLUENT 0 September 4, 2017 06:05
model of pipes inside pipe carmen FLUENT 0 January 22, 2009 10:27
