Re: deriving the Navier-Stokes viscosity term
Old   June 4, 2023, 14:25
Default Re: deriving the Navier-Stokes viscosity term
William Flannery
Dr Will is on a distinguished road
I have 3 references -
Sonin - Equations of Motion for Viscous Fluids - https://web.mit.edu/2.25/www/pdf/viscous_flow_eqn.pdf
Chakraborty - Navier Stokes continued
https://www.youtube.com/watch?v=0ndp5yAOklc - starting at 8:00
Fitzpatrick - Isotropic tensors
https://farside.ph.utexas.edu/teachi...d/node252.html
I'm trying to find an understandable derivation of the viscosity term of the N-S eqs. Sonin has a first principles analysis which is straightforward but a little too complicated ...
Chakraborty has what looks like a simpler approach using properties of an isometric rank 4 tensor. It's only simple, however, if the proof that an isometric rank 4 tensor has the required form, which he sort of proves, but ... does he?
Fitzpatrick has rigorous proof that an isometric rank 4 tensor has the required form. It's complicated.
So, my questions are, is Chakraborty's method rigorous or heuristic, and, what is the easiest way to derive the N-S viscosity term?
Dr Will is offline   Reply With Quote
Old   June 4, 2023, 15:00
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Why the isotropic tensor, are you looking for the bulk viscosity?
All is concerned to the viscosity is in the Newtonian model.
FMDenaro is offline   Reply With Quote
Old   June 4, 2023, 15:14
William Flannery
The relationship of the stress tensor to the strain rate tensor is specified by an isotropic rank 4 tensor.
Old   June 4, 2023, 15:26
Why don’t you start by Batchelor textbook?
Old   June 4, 2023, 15:59
William Flannery
I downloaded it (from pdfcoffee). It quotes the isotropic tensor theorem and uses that. Then there is an alternate derivation which is opaque to me.
Old   June 5, 2023, 05:38
Sec 3.3
T = A: grad V
Accepting that the fourth-order viscosity tensor A is isotropic for statistical reasons, you have only entries in the main diagonal.
The simmetry is applied for i-j indices.
Old   June 5, 2023, 13:04
William Flannery
Unless I'm mistaken, there is an easy proof that a rank 4 isotropic tensor has the required form ....
Let V = R2 to make it simple.
By rotating the axes 90 deg., f1 = e2, and f2 = -e1 it's easy to show the non-zero components of an isotropic rank 4 isotropic tensor T are [t1111 0 0 t1122; 0 t1212 t1221 0; 0 t1221 t1212 0; t1122 0 0 t111].
Why? t1111 corresponds to e1xe1xe1xe1 in e basis coordinates and f1xf1xf1xf1 (= e2xe2xe2xe2) in f basis coordinates, so t1111 = t2222, and similarly for components with 2 1s and 2 2s. If a component has 1 2 and 3 1s, for example t2111, it corresponds to e2xe1xe1xe2 in e basis coordinates and f2xf1xf1xf1 (= (-e1)xe2xe2xe2) in f basis coordinates and is hence 0. Similarly for a component with 1 1 and 3 2s.
Old   June 6, 2023, 07:58
Lucky
The point of introducing the isotropic rank 4 tensor is to show that the tensor can be no more complicated than such. That is, stress-strain relations and 4th order isotropic tensors are an extremely constrained class, there's only one form they can take. It's more a case of: what is the worst result possible?
It's not about deriving N-S from first principles. Newton's law is a law, stress is proportional to strain via an isotropic scalar.
How to add Source term (2) for PYROLYSIS - reactingOneDim Kummi OpenFOAM 10 April 12, 2021 22:11
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
How can use MacCormack & Baldwin artificial viscosity in term of generalized nonortho Nam Tran Ha CFD Freelancers 0 December 21, 2016 04:31
ILU for Navier stokes problems Raju Main CFD Forum 5 July 29, 2006 15:15
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 03:28
