May 31, 2023, 23:26 |
Boundary Condition for Boiling simulation
M Naarendharan
Rep Power: 6 |
Dear Community,
I am working on simulation of boiling heat transfer. The two phases (Liquid and Vapor) are tracked using a level set method. At the top of the domain, I am using an outflow boundary condition [setting the reference pressure as 0 and gradient of other quantities (u, v, w, T) to be 0]. With this boundary condition, I can observe a reverse flow of liquid at the top of the boundary when the vapor leaves the domain. I would like to know if this is normal or I should match the volume flow rate of vapor going out and liquid coming in. I wish to kniw if there any better way to treat an outflow boundary in case of two phase simulations. Thank you, |
June 5, 2023, 02:18 |
mathu
Hahaha I actually develop for CFX (although I work on TurboGrid, not the solver side). Changing state is very difficult to model because you don't actually model the cause-and-effect (conservation of energy is VERY hard to converge) instead we developed models for the 'macro' processes. They are only valid within certain ranges of conditions, and even then the convergence is limited.
pikashow ppsspp emulator Last edited by fasgya30; June 15, 2023 at 08:32. |
boiling flow, boundary condition, outflow boundary |
Wind tunnel flow simulation boundary condition issue | charan3007 | SU2 | 0 | October 21, 2021 09:27 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
