Maximum pressure for non-Newtonian flow past over cylinder |
May 31, 2023, 02:05 |
Kevin
Rep Power: 4 |
I am simulating a non-Newtonian flow past a cylinder. As I increase the diameter of the cylinder for the same Reynolds number, the maximum pressure over the cylinder decreases which contradicts what is mentioned in this paper: https://www.hindawi.com/journals/jmath/2022/3374763/ It's weird. This is what I get for Re=1000 And this is taken from the article: Can you help me with this please? |
cylinder flow, non-newtonian fluid |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 02:19 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 06:00 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Flow past cylinder (Re=10^5) | lbeaudet | Main CFD Forum | 9 | June 2, 2009 03:59 |
