Simulation of a saturation of a porous medium on ANSYS CFX
Old   May 18, 2023, 07:51
Default Simulation of a saturation of a porous medium on ANSYS CFX
Oluwagbemiga Fabunmi
Gbemiga is on a distinguished road
Hello my fellow CFD experts.
I have a question to ask. How do you model saturation of a porous medium like a sponge. I am using a simple design. A block that acts as the inlet into the porous medium and another block as the porous medium itself. I applied water vapour at 25 degrees Celsius and inputted the volume porosity and permeability losses. However, I am not sure my results are correct. When I check results for mass flow rate in the porous medium section, the mass flow rises and falls and eventually flat lines; remaining the same for the entirety of the simulation. I figured it should drop to zero steadily as the porous medium becomes saturated with moisture. I am running a transient analysis for 6 months, using a day as the duration of each time step. Please I need your inputs. Thanks
Gbemiga is offline   Reply With Quote
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 18:46
2Phase flow simulation in Porous Media Ansys Fluent Yaqub FLUENT 0 June 22, 2017 04:46
Simulation of flow through a Pump as turbine by Ansys CFX Aladinos05 CFX 6 June 13, 2017 22:34
Convergence issues for a 3D Centrifugal pump simulation using ANSYS CFX enr_venkat CFX 7 August 31, 2016 19:58
Help with 2D simulation of carbon dioxide migration through a porous medium bruno226 FLUENT 0 March 31, 2014 07:42
