SolidWorks Flow Sim - Discrepancy in heat transfer coefficient
Old   May 9, 2023, 08:21
Arrow SolidWorks Flow Sim - Discrepancy in heat transfer coefficient
SSG_NJ is on a distinguished road
Hi everyone!
How are you all doing?
Apologies but I was unable to find a dedicated SolidWorks Forum on the website.
I am working on a thermal model in SW Flow Simulation. I noticed a discrepancy in the value of the convective heat transfer coefficient ('h') obtained directly from the simulation (i.e. by using a surface goal) vs. calculating it via an equation goal using Newton's law of cooling, and I am unable to get to the bottom of this.
To verify which of these values are correct, I calculated the heat generated in the model (with an equation goal) using the 'h' obtained directly from the simulation (i.e. by using a surface goal) and compared it to the known value of heat generation which was inputted in to the model, and the two values differ greatly.
The flow is turbulent, forced, and the heat convects from a heat generation source directly onto the fluid.
Kindly help.
Thanks !
SSG_NJ is offline   Reply With Quote
Old   May 9, 2023, 11:52
CFDfan is on a distinguished road
below is the dedicated solidworks flow simulation forum (SWFS is actually a FloEFD code)
https://www.cfd-online.com/Forums/fl...orks-flotherm/
CFDfan is offline   Reply With Quote
Old   May 9, 2023, 12:54
Thanks! I'll ask there
flow simulation, heat transfer coefficient, solidworks
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Heat transfer coefficient near the wall in two phase flow XavierW Main CFD Forum 0 February 18, 2016 11:37
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
