inviscid flow paradox
Old   May 4, 2023, 19:09
Default inviscid flow paradox
hancock is on a distinguished road
The relevance of following mathematical statements to practical problems
1)“Inviscid flow” with a given Reynolds number
2) “Inviscid flow” with no slip wall boundary condition.
Also how can we simulate this in CFD?
Any references will be useful.
hancock is offline   Reply With Quote
Old   May 4, 2023, 20:46
Lucky
For engineering problems inviscid means you set viscosity to 0 or do not include the viscous force in your calculation.
Mathematically, inviscid means that viscous forces are negligible (i.e. very small). Although viscosity being equal to 0 is sufficient to show that a flow is inviscid in the classical sense, a finite Reynolds number is possible when one considers that a non-zero viscosity together with infinite strain (i.e. ridiculously high velocity gradients) can dissipate energy at a finite rate. There are practical applications for these flows in astrophysics for example where velocity approaches the order of the speed of light. You typically don't simulate these via traditional CFD like RANS with a turbulence model because handling infinite shear stress is not trivial.
Old   May 5, 2023, 05:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Statements 1) and 2) are wrong. Inviscid flows means the viscosity and conducibility are assumed zero. Therefore, Reynolds and Peclet numbers are infinite.
From a mathematical side, the character of the PDEs systems changes and you have to work with a system of hyperbolic equations.
There are several CFD textbooks (Leveque, Hirsch, Toro...) wherein you can study the formulations.
FMDenaro is offline   Reply With Quote
inviscid flow, no slip condition, theoretical
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Inviscid flow in sonicFoam chencw OpenFOAM Running, Solving & CFD 0 March 24, 2018 03:18
How would I write a 2d steady, inviscid, and incompressible flow simulation? 7he404guy Main CFD Forum 5 January 13, 2017 17:04
Inviscid Flow cfd seeker Main CFD Forum 0 October 8, 2012 01:53
Simulating NACA0012 for inviscid flow. Stan Main CFD Forum 2 May 13, 2005 15:22
