fvModels-accelerationSource - No velocity change
Old   May 4, 2023, 02:42
Wink fvModels-accelerationSource - No velocity change
Desh
dasith0001 is on a distinguished road
Hi Foamers,
I am trying to simulate an effect of fan, and I am using ''accelerationSource'' fvModel. I am using OpenFoam10
The fvModel works fine if I include 'halfCosineRamp' but I cannot see any changes to velocity field when I change it to ''constant''.
I am assuming the fan would exert a constant accelaration to the fluid. Would you take a look into the file ?
PHP Code:
accelerationSource1
type            accelerationSource;
selectionMode   cellZone;
cellZone        rotor;
U               U;
velocity        scale;            //constant; //uniform;
value           (0 0 10);
scale
type         constant;     //one;  //halfCosineRamp;  //constant;
                                      //halfCosineRamp; uniform constant
value        1;
//start           0;
        //duration        100;
Also, is this the 'right' fvModel to simulated the 'effect of the fan' ?
Thank you
Dasith
dasith0001 is offline   Reply With Quote
accelerationsource, fvmodels
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Change in velocity at inlet mutewinter Main CFD Forum 0 June 6, 2014 07:01
mean velocity change from inlet to outlet ro FLUENT 2 April 19, 2008 14:37
