Unstructured mesh extrusion with rotation in Pointe |
April 21, 2023, 02:26 |
Rep Power: 3 |
I want to make 3D mesh structure by rotating 2D structure 90 degrees. However, to make the unstructured mesh structure 3D with rotate pointwise, I need create a new line just below the mesh structure and then use that line to make it 3D (You can see it below "Rotation_axis"). However, when I do this, something like the image below occurs around the rotation axis (new_image). Will this affect my analysis? Normally my boundary condition in that surface would be symmetry. Should I apply the same boundary condition to the new surface formed here? Thank you! |
mesh 2d to 3d, pointwise mesh, unstructured mesh |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] 2D profile unstructured mesh | h3nn3 | ANSYS Meshing & Geometry | 2 | June 17, 2015 10:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
