Maksim
Rep Power: 6 ![]() |
Greetings, everyone!
I work on the modeling of compressible turbulent flows, and as a part of simulation i should somehow model turbulent diffusive heat flux, which appears in filtered equation of total energy. There is an ambiguity in the papers on how to do it. The two main approaches are ![]() ![]() ![]() ![]() Where ![]() ![]() Authors of papers do not provide arguments on the choice of the diffusive flow representation, and so i struggle to choose, which variant i should implement in my code? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It depends on whether your energy equation is written in internal energy or enthalpy and how the total energy is tracked (whether it includes pressure work or not). In other words, you have to write out the entire energy equation, you cannot get your answer by only looking at this one term. It is indeed ambiguous when you leave out the entire equation.
Maksim
compressible flow, turbulence |
Anisotropic turbulent heat flux. | Golaselo | Main CFD Forum | 2 | June 28, 2022 05:29 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Turbulent Heat Flux Question | deji | OpenFOAM | 5 | August 1, 2016 09:27 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
