FD NS implicit solver
Old   August 17, 2000, 09:48
Default FD NS implicit solver
N.SUBRAMANIAN
i am a research scholar in iit madras.i am in need of a finite difference navier-stokes implicit solver.either you provide me the solver or give me the guidelines for developing it.also guide me how to generalise the boundary conditions.
Old   August 17, 2000, 21:05
Default Re: FD NS implicit solver,answers?
John C. Chien
(1). Let us know the answer, if you have found one.
Old   August 17, 2000, 22:30
Istadi
I just succesfully developed the solver of Navier-Stokes momentum equation by finite-difference method. I applied the implicit scheme by utilization of SIMPLE algorithm that had developed by Patankar [Numerical Heat Transfer and Fluid Flow by Patankar, S.V., 1980, Hemisphere Pub.]. I applied the staggered grid to solve this problem to avoid zigzag pressure on it.
Beside this method, you can use the finite volume method that clearly developed by Patankar (1980). It's similarly. Please, to contact me if you have a problem about it.
Thanks
Old   August 18, 2000, 07:39
Default Re: FD NS implicit solver ?
Mehdi BEN ELHADJ
What a bout results given by your solver of Navier-Stokes momentum equation by finite-difference method ?
Old   August 18, 2000, 21:58
Istadi
I developed a source code to get a simulation about the streamline of 2D-velocity in cylindrical column of empty or filled by packed bed. This code utilize the algorithm of SIMPLE that developed by Patankar (1980). So, we can give the contour of pressure distribution in the domain. I had applied this system on a deep bed dryer simulation. Thanks
Old   August 20, 2000, 04:06
ram
how did you take care of the velocity profiles inside the bed..i presumen its a porous bed..?
Old   August 20, 2000, 23:24
Istadi
Hi, We applied conservation of momentum in the porous media by a volume averaging approach. This method has been succesfully developed by Liu et al (1999)[Liu et al., "Non-linear Flows In Porous Media", J. Non Newtonian Fluid Mech., 86, pp.229-252). For the friction of body force, we applied Ergun correlation for pressure drop in the packed bed. So, we can solve it by FDM or FVM. Thanks
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
need for an unsteady implicit solver suitable for large timestep dinonettis OpenFOAM 2 May 26, 2010 07:57
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 04:01
implicit solver john Siemens 1 November 11, 2003 09:55
