Prandtl's Classic Lifting Line - Zero Lift AoA |
March 15, 2023, 19:50 |
William Sauls
I am trying to write a simple piece of code to calculate wing parameters for a few different wing configurations, but I do not know whether to treat zero lift angle of attack as a positive or a negative number. In cl vs alpha graphs, the zero lift angle is always negative for cambered sections. I have attached the formula I am using, taken from Anderson - Fundamentals of Aerodynamics.
lifting line, prandtl |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[Gmsh] No cells read from file ".msh" | hwsv07 | OpenFOAM Meshing & Mesh Conversion | 5 | August 13, 2018 16:42 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 22:24 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
