Unexpected velocity profiles for pipe flow with elbows
Like Tree4Likes
Old   March 9, 2023, 12:59
Default Unexpected velocity profiles for pipe flow with elbows
Baptiste
K-al-Eps-o is on a distinguished road
I am solving an internal flow inside a succession of elbows with openFoam (v2206).
The solver I am using is simpleFoam with a kOmegaSST model.
My BC are fixedValue uniform velocity profile with zeroGradient pressure at inlet and zeroGradient velocity with fixed pressure at outlet.
Walls are of patch type 'wall' with wallfunctions. To take advantage of the symmetry, only half of the domain is modeled and a boundary of type 'symmetryPlane' (I tried to use 'symmetry' and 'slip' boundary conditions that both led to the same problem) is used.
The velocity profiles I get are very strange and I can't explain where this comes from. For some reason, the velocity is 'damped' at the symmetry plane (which is the plane in the middle of the full domain. Both longitudinal and vertical velocity are exhibiting a M (or W) shape velocity profile along the width (X coordinate) of the domain.
Attached are three pictures.
  • The first picture shows the computed domain.
  • The second picture shows the velocity magnitude on two slices. One cutting the domain in its length and one cutting the domain in its width, perpendicular to the mean flow and located after the third elbow. On this picture only half of the domain is shown, with the symmetry plane on the right side. The velocity profile on this plane is very strange with a damping of the velocity at the symmetry plane.
  • The third picture shows the full domain (using the mirror of the half-domain computed) and velocity profiles along the width of the domain at a certain height and along the height of the domain at the middle of the domain. The bottom left graph shows that the velocity profiles are 'damped' at the symmetry plane, an unexpected behavior.
I can't find what is wrong with my simulation.
K-al-Eps-o is offline   Reply With Quote
Old   March 16, 2023, 20:24
Lefteris
Aeronautics El. K. is on a distinguished road
You said that you have applied a fixed value uniform velocity at the inlet.
Your inlet is not aligned in the global X-Y-Z, it's at an angle. Have you checked that the velocity you have applied is normal to the boundary and not aligned to the global X-Y-Z?
I'm a bit rusty with Of, does it have a flow rate boundary condition? If so, what happens if you try that instead of the velocity?
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   March 20, 2023, 09:11
Baptiste
Dear Lefteris,
Thanks a lot for your reply.
The pictures are misleading, but the geometry is well aligned with the X-Y-Z axis (I doubled checked). The issue might come from something else.
To continue my investigations, I used three different meshes (cf figure below, from left to right):
  1. Mesh1: This mesh (which is the same mesh used to generate results of my first post) models only the left half of the domain. The face with the normal in the positive X direction has "symmetryPlane" as a BC while other wall faces have the "noSlip" BC. This mesh has inflation layers on every external face, except inlet and outlet.
  2. Mesh2: This mesh models the full domain and doesn't resort to symmetry plane. It has inflation layers on every external face, except inlet and outlet.
  3. Mesh3: Same as the Mesh1, this mesh models only the left half of the domain with a symmetry plane ("symmetryPlane" BC) at the face with normal pointing in the positive X. However, the face with the symmetryPlane BC has no inflation layer.
With Mesh2, I wanted to check what was the correct solution, without using symmetryPlane BC. The solution (see figures below) showed a different (more realistic) solution than with Mesh1.
With the mesh3, I wanted to check if the inflation at the symmetry plane was causing issue. It turned out that the solution with no inflation at the symmetry plane gives a result very close to the one modeling the whole domain. I concluded that the inflation was causing trouble. Is this common knowledge ?
Finally, I am a bit confused by the results. I am expecting the flow to detach from the wall at the elbow, but it seems to stay attached. In addition, I was expecting to observe Dean Vortices, as described in the literature. Do you have any guess about what could be wrong ?
Thanks again for your help.
Old   March 20, 2023, 10:46
Steve Lainé
slaine is on a distinguished road
Can you provide the geometry?
slaine is offline   Reply With Quote
Old   March 21, 2023, 03:40
Baptiste
Sure. Here it is attached.
slaine likes this.
Old   March 21, 2023, 05:02
Steve Lainé
Was the inlet flow rate 50m/s? That is quite a high flow rate.
As a sanity check I have run it in SimScale using incompressible OpenFoam as the solver.
Old   March 21, 2023, 05:42
Baptiste
Attachment 93881
Attachment 93880
Attachment 93882
Attachment 93883
Yes, 50m/s. Fluid is air.
Your result is close but a bit different than mine. Did you simulate water or air ?
Old   March 21, 2023, 05:49
Steve Lainé
OK. I used water. Are you running compressible or incompressible with air?
Old   March 21, 2023, 05:52
Steve Lainé
The symmetry plane is definitely not working as intended. What does your mesh look like in a cross section? There should not be boundary layers on the symmetry plane:
In my simulation with a symmetry plane the velocity behaves as expected.
Would it be useful to have the OF setup? You can download that directly from the project here.
Old   March 21, 2023, 05:55
Baptiste
Incompressible. Mach number is small enough to consider the flow incompressible.
Old   March 21, 2023, 05:59
Steve Lainé
OK, rerunning with air at the shared link.
Old   March 21, 2023, 06:01
Baptiste
As I was explaining in this post (but for some reason the picture with the mesh is missing), I tried different meshes (that is why you see three different results.
In fact, the mesh with an inflation layer is the one that created the issue.
Here is a picture of the meshes.
Dear Lefteris,
slaine likes this.
Old   March 21, 2023, 06:03
Baptiste
In fact, it seems to be the origin of the issue. Do you have an explaination why ?
Old   March 21, 2023, 06:05
Baptiste
Thanks a lot. By the way, the geometry I sent you is already the half domain !
slaine likes this.
Old   March 21, 2023, 06:13
Steve Lainé
See results with air here:
Old   March 21, 2023, 06:18
Steve Lainé
This is what I suspected. You want the symmetry plane to represent bulk flow as opposed to a wall with a boundary layer. I am not familiar enough with OF local to know what setting you need to change. However, I suspect that the symmetry plane has not been set correctly. It is acting as a wall as opposed to a symmetry plane. Did you assign a wall boundary condition to the symmetry plane? It should be assigned as only symmetry.
Old   March 21, 2023, 06:28
Baptiste
My setup is explained here:
Dear Lefteris,
What is weird is that I applied a symmetryPlane BC on both meshes but the one with the inflation layers acts like a wall.
Anyway, now I know.
Thanks a lot for your help !
slaine likes this.
Old   March 21, 2023, 06:29
Lefteris
For whatever reason I can now see your responses. I couldn't yesterday. Anyhow.
Dear Lefteris,
Understood.
Yes, I'm not sure why you'd have prism cells (or inflation layers or however anyone calls them) on a symmetry plane. It doesn't make much sense.
Some software by default don't allow prism cells on a boundary that is not set as wall, even if you try to define them (the layers) in the mesh controls.
So perhaps in OF, by asking the mesher to build layers, this tricks the code to think that that's a wall and then goes and models a boundary layer...
I don't know, I'm just guessing here.
Finally, I am a bit confused by the results. I am expecting the flow to detach from the wall at the elbow, but it seems to stay attached. In addition, I was expecting to observe Dean Vortices, as described in the literature. Do you have any guess about what could be wrong?
Not quite sure. The standard answer would be to check the fluid properties, the boundary conditions at the inlet and outlet, turbulent quantities and of course the mesh. If that doesn't work, you can always question the assumption of steady state flow.
Lefteris
Old   March 21, 2023, 06:31
Steve Lainé
You are very welcome. I am glad that I could be of assistance.
Old   March 21, 2023, 06:34
Baptiste
I tried to solve the flow with an unsteady solver. It gave me (the same) steady result
openfoam, simscale, symmetryplane
Is it possible the velocity profile changes in the fully-developed turbulent flow? czx0415 FLUENT 0 July 9, 2020 17:25
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 12:25
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
