Intensity and Viscosity Ratio for a pipe cut by periodic boundary
Old   February 23, 2023, 05:40
Default Intensity and Viscosity Ratio for a pipe cut by periodic boundary
Mir Reza Negahban Alvar
Mir Reza Negahban Alvar is on a distinguished road
I have a pipe that the fule enters from one part and it is an inlet to the domain. The whole pipe (and the domain) is cut into 5 pices like a pizza cut (seen from the axial cross section) , and both side boundaries of the pipe are set periodic boundaries. Now the question is that for the inlet condition if I want to set Turbulence specification method to Intensity and Viscosity Ratio, what will be THE Hydraulic diameter?
Mir Reza Negahban Alvar is offline   Reply With Quote
hydraulic diameter, intensity, periodic, viscosity ratio
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
