February 19, 2023, 19:32 |
How to improve convergence in Fleunt?
Peyman
Rep Power: 5 |
Hi all.
I am doing a simulation for clot formation and I developed 28 UDS. I have to simulate it for 60 minutes. The biggest time step that I can have is 10^-5s. I am using parallel simulation with 2 cores. (In this situation, the simulation will take a couple of months) When I increase the cores there is no effect on simulation speed. I would appreciate it if any of you could give any advice on how I can increase the speed of my simulation. I already tried to decrease the under-relaxation factor (0.3, 0.5,08) and decreased element number, but they didn't have any effect |
February 20, 2023, 03:08 |
Arjun
Rep Power: 35 |
"I have to simulate it for 60 minutes. The biggest time step that I can have is 10^-5s."
You did not mention anything about the models involved and what is restricting this time-step. If you are open to other softwares then you can try wildkatze. I am sure it could go much faster there (or made to go faster ). (I develop wildkatze so i know what is possible there). (60 minutes it still high but usually you can get away with much larger timesteps in wildkatze). |
February 22, 2023, 04:19 |
Joern Beilke
Rep Power: 20 |
The recommended strategy is to increase the relaxation factors and reduce the number of inner iterations.
February 22, 2023, 07:04 |
#4 | |
bigfoot
Rep Power: 21 |
Your parallellization is not working correct it seems. If you are using user defined functions, make sure they are properly parallellized. Also check with a simple (but large) test case that parallelization is working correctly. |
February 22, 2023, 12:18 |
Peyman
Rep Power: 5 |
February 22, 2023, 12:23 |
Peyman
Rep Power: 5 |
While using 2 core the process is faster in compare with 1 core. But after increasing to higher cores there is no effect. It seems that parallelization I correct. I have a small geometry with 50k messh element. And it is very wired that why convergence is not good . Do you have any idea ?
February 22, 2023, 18:50 |
#7 | |
Rep Power: 17 |
February 24, 2023, 14:40 |
#8 | |
Peyman
Rep Power: 5 |
I am solving 29 equation which are coupled with each there. It seems that the RAM is effect the speed. what do you think? |
February 28, 2023, 05:44 |
#9 | |
Hamid Zoka
Rep Power: 19 |
Solution algorithm has an impact on convergence speed. E.g. coupled algorithm takes more CPU time compared with SIMPLE. best |
March 3, 2023, 20:44 |
#10 |
Peyman
Rep Power: 5 |
convergence failure |
How to determine the convergence of solutions | cfx_ws1992 | CFX | 6 | November 9, 2017 17:12 |
Improve simpleFoam convergence | Daniele111 | OpenFOAM Running, Solving & CFD | 43 | November 6, 2010 12:50 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 19:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 11:55 |
